Oh, I thought we were talking about the OP's amps. Sorry. I guess he still hasn't posted photos of the underside.
Sorry, I sold my MC60s.
I guess I'm not the only one.....................Oh, I thought we were talking about the OP's amps. Sorry. I guess he still hasn't posted photos of the underside.
I am not trying to be a deep shxt to bash MC60, BUT the musicality and enjoyment of MC30 is beyond a technical level, they just sound right, the rightness clicked my brain.I guess I'm not the only one....................
Thank you for pointing that out.From the looks of it, there are original carbon comp resistors in the signal path. Whoever did this had good discipline.
who ever did the work used some nice parts. Those caps were all the rage maybe 10-12 years ago. Some high end OEM manufacturers used them for a period of time.Thank you for pointing that out.
The “air” in the music is just different. Me likey
what would “on” value and “off” value entail in terms sonic signature? any idea?Caps all appear to have been replaced, I see some old resistors but so long as they are on value its fine. Even off value its unlikely to hurt anything.v
that is very precise, wow. i don’t even know what it means and will look it up![]()
One blue Sprague Atom electrolytic cap appears to have a manufacturing date of the 5th week of 2010. [1005H592...]
you may not hear it exactly, but it will often measure as higher distortion than it should, or you may get hissing or static noises if the resistors are failing in a noisy way. Voltage measurements may also show things as being out of spec.what would “on” value and “off” value entail in terms sonic signature? any idea?![]()
quite a bit to unpack here (and with other replies, too). This is extremely new to me so I will have to look up the roles of “feedback loop” and what those different capacitors mean. For now, I have hooked up the MC60s to a WiiM Ultra Streamer and am really loving what they can do in my study room with Sonus faber Electa Amator III speakers. The (getting into audiophile terms now) placement of instruments in familiar tracks is “new”. Some instruments land in the middle of the room, for example, which I did not expect. Is it the recording itself? Or is the amp playing a role? I think it’s the latter, because this is new experience for me, listening to the same track.who ever did the work used some nice parts. Those caps were all the rage maybe 10-12 years ago. Some high end OEM manufacturers used them for a period of time.
Likely still quite good. I would listen to them as they are. My guess is they sound pretty good. a
The only thing I might consider doing is adding a .33uf film cap as a bypass to the 100uf electrolytic in the feedback loop.
The markings inside the amp likely indicate which transformer tap was wired into the primary and likely a measurement value for the bias voltage for the 6550 tubes.
