I had mentioned the Hafler in another thread, which got me thinking. I thought I would post my discovery.
I haven't finished troubleshooting it, my real work got in the way but I did have time to hook it up to the Signal generator, Fluke - set to AC, 8 ohm load and scope.
The right channel works well up to 19.4 volts AC with no clipping. After that it blows the speaker fuse.
The left channel is oscillating right off the bat.
Visual inspection:
Inspection of the left channel reviled two 100 ohm resistors R27 and R33 toasted, melted but still reading 99.9 ohms.
Tested all the transistors on my trusty DCA75 Pro and they all check good. Pre's, drivers and outputs.
Started checking the diodes but couldn't finish due to work. So far they check fine.
Note: I did a visual check of the boards but missed the burned resistors. Of course I didn't see them until I had the board loose. They may of been all right before I ran the amp for the checks.
The previous owner said it sounded distorted on the left channel.
Hafler DH-200 Service Manual
Visual inspection:
Comparing 200 (pc-6) and 220 (pc-19) driver boards. The only differences are that they added a dc offset adjust circuit, they changed the current sources to resistors in the input stage, they added a 120 pF cap from collector to base of Q 13, and they changed the base stop resistors (R40 and R41 (on the PC6 board) from 220 to 470 ohms. The last 2 were probably to improve stability, as the mosfet outputs tend to oscillate if gate resistors are too low. Maybe it will help to add the cap and change the resistors. YMMV
