Kevin Kreigh
Hello. I replaced transistors on my Sansui 2000a F-1222-1 tone/pre amp and F1180 driver board with KSC1845. Went OK. My soldering skills are not great. Both left and right channels working fine prior, but with audible noise-I had read several things about the transistors, so I went for it.
If I plug a source into main input, all sounds great-both channels with reduced noise. So, perhaps I did something on pre amp? Transistors are pinned correctly. I've checked over and over. I do get audible, kind of like small pop from right channel when turn on receiver, but no music from any attempted source, except plugging into main input. Any help and guidance much appreciated.
Thank you!
Thank you!
