Yes!Are those the ones I saw on FBM?
Do you have a picture of the boards? Do you know if they are the regular PASS A40 boards? I have some A40 boards from back in the Audio Amateur/ Old Colony Sound Labs days. I also have a stash of the unique Lambda Darlington output transistors. I built an A40 in a SUMO Andromeda II chassis years ago and still have it.
Craig
Moderate output doesn't require high rail voltage. And, being Class A, it's sorta like your question on Class G/H. Keep the voltage low as possible to minimize dissipation as much as possible.Only 40V rated main filter caps?
That seems very low to me.
What am I missing?
If I recall properly, my 25wpc @8, 50wpc@4 PasssDIY F6 is maybe 25V rails.
Got shot down, was told it’s not a Pass Labs product and to ask on the forums.Those are NOT the standard A40 boards. I would get over on PASS Diy and see what Nelson has to say, he just might have some old boards laying around. I got a pair of the regular A40 boards from him when the Old Colony Sound Lab boards sold out. He might even have a schematic. You should be able to get some history about the amps from him.
On the working one, someone replaced them with MJ15024 and 25, four of each on each channel, 16 devices total per unit.With those blue circuit boards it sure looks like a Threshold era product. What type of output transistors does it use?
I looked at Pass DIY, nothing. Someone else posted these on DIYaudio with no response using the photos from the FBM ad.Did you check PASS Diy or the PASS forum on DIYaudio?
