No, not really. Low is good, it helps negate cable and other loading issues. Many CJ preamp line stages are simple cathode follower or similar line drive, and may invert acoustic polarity. See instruction manual for the specific model for particulars.
As
@wyn palmer
Is there a possibility that the 200 ohm output of my Conrad Johnson is too low? Llike they may have made it to mate with a CJ mosfet amp?
Thanks for the info.
Dave
The issue of "desirable output impedance range for a preamp" is a complex one, so let's look at a few issues.
1. Output bandwidth/load considerations.
In general, having an output bandwidth greater than say, 500kHz is hard to justify, and it's perhaps better if it's significantly less- say 200kHz. Less than that and some attenuation at 20kHz starts to appear, more and unwanted signals can pass through potentially exposing the power amp to intermodulation of out of band signals down into the audio band.
3kohms and 250pF or 300ohms and 2500pF give you c.200kHz. Low capacitance video or phono cables are c. 20pF/ft and if you have multiple runs to various devices several hundred pFs is not unlikely. Also the input stages of some power amps can be quite capacitive- the Rogue M180 looks like about 4000pF! All this put together suggests that the stage should be designed to drive a capacitance in the order of 5000pF max while keeping a bandwidth of c.200kHz. That suggests an output impedance in the 150 ohms region.
2. Output stage stability.
Open loop stages are generally not subject to stability issues. This is not entirely true, but it might as well be.
Stages with negative feedback often do require an additional resistor in series with the output in order to maintain stability due to the phase shift introduced by the capacitive load. Counter intuitively perhaps, this resistor gets smaller as the capacitive load gets bigger and it gets bigger as the closed loop bandwidth of the driving stage gets smaller. However, this resistor generally falls in a range between c. 1 ohm and several hundred ohms.
There is also no downside, from a stability point of view, in having too large a resistance.
So, all in all 200 ohms seems like a pretty fair value to have.
