I posted about this on another message board, but I thought my fellow AKers might be interested...
For me, the biggest barrier to fully enjoying vinyl has been cleaning. I don't own a cleaning machine, though I probably should. I have a Spin Clean, and have tried to keep up a regular regimen of cleaning, but I have found the Spin Clean hard to use - the inserts keep popping out, turning the records requires a lot of force, etc. So I often don't clean new albums. I just brush them before playing. I've even skipped cleaning used records I trust.
But knowing that's not good practice, mostly what I've done is listen to CDs.
As of this week, that has changed. I bought Humminguru's new EZ Record Washer. It retails for around $100 and is aimed squarely at the Spin Clean market. In some respects, the products are similar. Both are completely manual operation. Both require you to fill a tank with distilled water and the company's cleaning fluid. But there is a huge difference between the two: instead of having to rotate records by hand, Humminguru has come up with an ingenious handle-crank, which makes cleaning fast and easy. You mount the record into the cleaner, turn the crank clockwise 12 times and 12 times counter-clockwise and you're done.
I cleaned eight records yesterday without breaking a sweat and I'm actually looking forward to my next cleaning session, something I didn't think was possible.
Again, this obviously isn't for people who are deeply into cleaning and have automated machines and the rest. But if you have a modest vinyl setup and are looking for a no hassle way to keep your albums in good shape, you can't do much better than this.
