Make sure the DMM is set to read AC volts rather than current when you connect it across the resistor. The entire idea of the resistor being there is to allow AC current to be measured using an AC voltmeter; if your DMM has an AC Current setting (most can only handle DC current), you wouldn't need the resistor at all. Once the DMM is set to read AC volts, it'll be safe to connect the probes across the 1 ohm resistor, but keep your fingers away from them.Very simple and clever. If I have a DMM with current reading I assume I can simple connect that in series with the live lead?
Don’t want to fry my meter.
-Adam
