BadBoyBubby
Schematic: hfe_pioneer_sx-780_ku_kc_schematic_en.jpg
Service Manual with Board Layout: http://akdatabase.com/AKview/albums/userpics/10007/Pioneer SX780 Service Manual.pdf
As a foreword, I'm not very advanced at troubleshooting electronics, but I gave it my go and would appreciate if anyone can give me some tips or point me in the right direction. I've mostly been checking transistors by measuring the forward and reverse voltage across all the PN junctions and making sure it seems reasonable. My initial assumption was that a transistor had shorted and that's why I was seeing rail voltage on my inputs.
I recently ran into an issue where I was under the impression I blew one of my power packs. Couldn't get power relay to click. So I went with the STK-0050-II discrete component replacement mentioned on the forum elsewhere. I soldered everything up, checked it out, and installed with a DBT. Powered on and the bulb was bright. Powered down, unsoldered the new amplifiers, and soldered in 2 x 1kohm resistors between pins 1-3 and 0-8 on both channels. I have the following voltages between these pins and chassis ground which leads me to believe there is something wrong in front of the right power amplifier that is pinning the input voltage to the rail.
Right
1: -37.2 V
2: -37.1 V
3: 0.00 V
8: 0.00 V
9: 37.4 V
0: 36.4 V
Left
1: -1.5 V
2: -37.1 V
3: 0.00 V
8: 0.00 V
9: 37.3 V
0: 1.5 V
Additionally, with the resistors wired in the protection relay will pull in.
I checked the forward and reverse voltage for the Q12, Q14, and Q16.
Q12 (NPN):
BC: 785 mV
BE: 810 mV
EC: 778 mV (Q14 BC measurement
EB/BC/CB: OL
Q14 (NPN):
BC: 778 mV
BE: 804 mV
EB/CB/EC/CE: OL
Q16 (PNP):
CB: 752 mV
EB: 777 mV
BE/BC/CE/EC: OL
So everything seems okay with those transistors from what I can tell. (After being really confused why I had forward voltage across the emitter collector of Q12 for a minute lol)
So I've moved upstream to measure Q8 and Q10.
Q8 (dual PNP transistor (Not really sure what this is called)):
Pretty sure pin out is B1, C1, Shared Emitter, C2, B2 but maybe I'm wrong
C1B1: 769 mV
EB1: 803 mV
C2B1: 772 mV
EB2: 807 mV
All other directions OL
Q10 (dual NPN transistor (Not really sure what this is called)):
Pretty sure pin out is E1, C1, Shared Base, C2, E2 but maybe I'm wrong
BE1: 642 mV
BC1: Shorted
BE2: 762 mV
BC2: 756 mV
All other directions OL (besides C1B)
Finally measuring Q6
BC: 792 mV
BE: 811 mV
CE: 1085 mV? Measuring up through D2 or something?
Am I approaching this the wrong way? I'm thinking now maybe I should be checking voltages at all of these points and looking for resistor issues? Sometimes the schematic and layout drawing confuse me because they don't totally match what I'm seeing on my PCB. I'm guessing it's due to revision changes though. One thing that does seem seem weird is that R252 has a wire ran next to it connecting the nodes. Same with R261. Seems factory, but I don't understand the purpose since it seems there would never be a voltage across these resistors. These wires are the blue ones in the photo I attached.
Also, am I even accomplishing anything by measuring reverse breakdown of the PN junctions and across the transistor emitter-collector and vice-versa?
Also, I measured the 0.22-ohm resistors and they seemed fine. After measuring my lead resistance and then them they're around 0.3-ohm which seems reasonable given the quality of my meters.
Right
1: -37.2 V
2: -37.1 V
3: 0.00 V
8: 0.00 V
9: 37.4 V
0: 36.4 V
Left
1: -1.5 V
2: -37.1 V
3: 0.00 V
8: 0.00 V
9: 37.3 V
0: 1.5 V
Q12 (NPN):
BC: 785 mV
BE: 810 mV
EB/BC/CB: OL
Q14 (NPN):
BC: 778 mV
BE: 804 mV
EB/CB/EC/CE: OL
Q16 (PNP):
CB: 752 mV
EB: 777 mV
BE/BC/CE/EC: OL
C1B1: 769 mV
EB1: 803 mV
C2B1: 772 mV
EB2: 807 mV
BE1: 642 mV
BC1: Shorted
BE2: 762 mV
BC2: 756 mV
BC: 792 mV
BE: 811 mV
