I have these there:
I've heard nothing other than the email that you forwarded to me. Was wondering myself about their plans.Tangentially, have you heard anything more from SOTA beyond the initial rapture on listening to the V4?
I'll contact them. At the very least you should have your unit returned.I've heard nothing other than the email that you forwarded to me. Was wondering myself about their plans.
I’ve got a v3.2 board if that's of interest.as i'm listening to the V1.3 stage right now killing it, but having been out of the loop for a while: is it worth doing anything with my spare V1.3 board that i originally sat on the shelf, or should i hop straight to the V4 if i want to add a second stage into my spare chassis space?
And the output relay works predictably?Hi Wyn,
I used the ZPD4.7 at D18 as per the excel BOM file, which I think was from the Dropbox folder.
It seems possible that the V4 will be commercialized, but will go to SMD, so more work to do.
The zener/1N914 change is there just to make the operation of the emergency turn off more certain by ensuring that the voltage on the control line does not rise too high.Great!
Is the Zener/1N914 swap likely to make a difference? On power up I certainly get a delay before the outputs are enabled, as you intended. I haven't wired up the mute switch but presumably that would result in the same delay?
