I’ve restored an HK930 and HK 730, both of which have been working great. I clean them, replace the Electrolytic caps, and repot the power transistors. The HK 670 sounds great, and I was getting ready to button it up, when I noticed that the left heat sink is hot to the touch, while the right heat sink is at room temperature. I did a visual check of the components and nothing seems damaged. I checked the idle voltage at the speaker outputs. They are both high at -0.350 volts. The Service Manual says the should be +-20 millivolts. One of the things I found odd about this receiver is that there’s a diode inside of a spade connector that attaches to the heat sink. I have no idea what it does, but the left channel’s one was broken, so I replaced it with a spare from another HK670. Any suggestions would be appreciated. I’m a mechanical engineer and not very good at troubleshooting. I am pretty good at soldering, and can use a volt-ohm meter.
