Hi Folks, I have a 97 Ford Ranger, 2 wd, 5 speed, has 216,000 miles on it. About 4 years ago I had the clutch replaced and while having that done the mechanic suggested replacing the slave cylinder since it is the type mounted inside the bell housing, and when they go it requires dropping the tranny. So four years have passed, the truck runs fine with a lil exception.
A couple of weeks ago I was driving it to and from work, parked it as usual. When I started it up and tried to back out of the parking spot it would not go into reverse. Finally I shut it off, put it in reverse, restarted it and backed out. It would not go into first, so I repeated the process, shut off engine, put in first gear, start it up, and away I go.
I checked the fluid, the reservoir was low, but not empty, I topped it up. I brought it to the mechanic, he could not find any leaks, said he looked inside the inspection hole in the bell housing and it was "as dry as a popcorn". He bled the line, said there was no air bubbles that he saw. He took it off the lift and I drove home ( about 30 miles) and it felt fine! over the weekend I was driving it and suddenly I got a repeat situation, no reverse or first gear. The fluid level looks ok, but obviously something is wrong. How can I test the master cylinder and the slave cylinder? I assume one is not functioning. Advice? Opinions?
