Catfish Phil
New Member
This was one dirty, filthy 2230 - clean under the chassis but dirty on the top side, with rusty transformer and tuner boxes, missing button on a broken power switch, almost all bulbs burned out and scratchy pots.
Brought up the voltage slowly and wow, it came back to life.
Sprayed out controls, and everything was fine - nice and loud, good on AM and FM, so proceeded to clean up the cigarette smoke damage by vacuuming out everything and then washing off one pc board at a time with alcohol and a plastic brush. Helped out the drying process by vacuuming every pc board after the wash/rinse/repeat cycles. Let it all dry a day or so before powering it up.
The amp section sounds great but I am hearing a loss of sensitivity on the FM band and loss of the AM band altogether.
So, trying to figure out where I went wrong when doing the following things:
The two tuner section box tops were rusty - removed them, removed the rust off the variable capacitor box but the smaller shielded box lid was nasty. Wire brushed it, rust treated and painted it.
Removed the ferrite rod antenna to clean it and the mounting bracket. Wondering if one of the ferrite antenna wires is stretched/broken where it enters the rod housing. Marantz used the shortest piece of wire in the factory on this one. Thinking if the red wire is broken at the antenna, no signal is getting to the AM tuner section. A little fearful of disassembling the ferrite antenna and cracking it in an attempt to see if the wires are broken.
Was careful to not disturb any of the toroid coils but some of the alcohol could have found its way into one.
The receiver has been on and working 12-14 hours/daily for the past five days. Everything is running cool, and the FM sensitivity seems to have improved a little bit, but the AM band is still dead. AM was working well before the cleaning.
Any ideas?
Any ideas?
