View attachment 1114188 did some research and these seem to be a bit hard to find, and they get a decent review. i am picking these up tomorrow i think. if i do i will send picks.
2240, 140 power amp, 1030 integrated, 5200 Cassette deck, 104b and 105 tuner, and an in need of love 1060
Remember the weight factor. That's a lot of vertical weight multiplying downward...just sayingJust worked out that the IKEA Kallax 4x4 will comfortably hold 1280 LPs.
With the right dividers, it should hold about the same number of CDs.
Tempting...
Polk SDA SRS 2.3 TL and some jackass standing there
Now I'm out
Watched a vid where a guy glued every dowel and every joint. Then he used masonite as a backer, glued and screwed.Yes, I put a drop of wood glue in each hole, And added a finished ply backing painted white. I'll get a pic up as soon as room is lighter. Very strong shelf, No bowing from weight, I hate that.
Will the judges be encouraged to tip?.....
I'm afraid of the "whoops, that doesn't go together like that" factor. LOL.
My wife says my stuff will be dusted regularly and no one will be allowed to touch it. Because it was mine. You know kinda like a museum.
Well one thing is for sure. She plans on out living me.
Can't beat that steel rack, except that it was full on day one!Good point. I’m probably better off with my steel rack, for LPs anyway.
Was considering white peg board. Glued and screwed for stabilization. That way I could see each shelf an hit it with a screw...I'm probably overthinking this.I screwed the backing on. Not much to grab onto. I pre drilled the board first. Went ok, But dicey
