aabottom
Swing
I completed my first Vinyl to Digital Transfer today. For my first vinyl to wav to CD transfer, I picked Emerson, Lake & Palmer (Cotillion SD 9040), an LP that’s been in storage for 13 years.
For vinyl LP recording, I use a Dell Optiplex GX400 running Win2K with the OEM sound card. Audacity 1.3 Beta creates a wav file on the hard drive. Then Winamp 5.572 burns the wav file to CD-R.
Now I can play the wav file on my PC/ Winamp music server or the CD-R on any CD-R compatible CD player. The wav files on the hard drive is 838 MiB for about 41:22 min:sec of music. The CD-R works in my Sharp DX-650 CP player.
I’m not sure I can tell the difference between the vinyl, the wav file, or the CD. I suspect I have some more tweaking to do. Such as setting the Input Volume (in Audacity) to avoid clipping.
A summary of the audio signal path follows.
1. The Phillips GA312/ Stanton 681 EEE (turntable/ cartridge) with OEM RCA phono cables inputs to the phono input of the Yamaha RX-797 (receiver). The Yamaha RX-797 is set to PURE DIRECT mode.
2. From the RX-797 MD/TAPE OUT, a 6 feet RadioShack audio y-cable (dual RCA phono male to 1/8” stereo male, gold plated) sends the analog signal to the LINE IN of the OEM sound card (Analog Devices Inc., model SoundMAX Integrated Digital Audio) in the Dell Optiplex GX400.
3. The software used is Audacity 1.3 Beta set to record at 88.2 KHz, 32-bit float. Other settings are Rate Converter: High Quality Sinc Interpolation; Dither: Shaped.
4. Then, Winamp 5.572 burns the wav file to CD-R on a MAD DOG 16XDVD9A4 DVD/CD reader/writer installed in the Dell Optiplex GX400.
Vinyl to digital path
_____________________________Analog____________________________
Phillips GA312/ Stanton 681 EEE/ = OEM RCA analog cables =>> |
Yamaha RX-797 receiver --------------------------PHONO IN << |
Yamaha RX-797 receiver ----------------------MD/ TAPE OUT >> |
SoundMAX LINE IN <<=1/8”stereo === 6ft === RCA phono =<< |
_____________________________Digital___________________________
Dell Optiplex GX400 (Windows 2000)
Analog Devices Inc./SoundMAX Integrated Digital Audio << LINE IN
Audacity 1.3 Beta -> Internal hard drive
| | Rate: 88200 Hz; Format: 32-bit float;
| | Dither: Shaped
Winamp 5.572 / CD burn ->
MAD DOG 16XDVD9A4 DVD/CD reader/writer -> CD-R blank
References
[1] best Vinyl to Digital tranfer
[2] http://www.audiokarma.org/forums/showthread.php?t=270075
post #31 by rkay5 on 20091222 1128
| | Dither: Shaped
References
