Ok, it only stands to reason, a clean record is a quieter record. Pure Vinyl is good... The question as long as I can remember, when it comes to vinyl, expecially 40 year old vinyl with unknown history is how to get it clean and keep it there.
Back in the 70's. I used Parastat, Discwasher, Vac-O-Rec and many other methods to clean records. I still like a Vac-O-Rec and Zerostat for nice clean records. But when I find some vintage vinyl at a garage sale or thrift, the thing I want to do, before my styli hits it, is get it CLEAN! I have passed on dusty looking records without scratches, that I would have loved to had if they just weren't so dirty.
OK, I have for years used tap water and dish soap to "deep clean" records, but it was always obvious that it left a residue. A residue that one could see..
Looking for a better solution (literally and figuratively), I read a a post by drknstrmyknight (Frank) where he suggested Tergitol. Frank is semi-local, so I thought I'd contact him and see what he knew..
He suggested the following:
"The Canadian Conservation Institute (CCI) recommends the use of nonionic, ethelyne oxide condensates surfactants to clean sound recordings. The CCI does not foresee long-term problems associated with the use of nonionic surfactants such as Tergitol. Tergitol 15-S-3 is an oil soluble surfactant and 15-S-9 is a water soluble surfactant. Combined they remove a wide range of dirt and greases and can safely be used on sound recordings. Use 0.25 part of Tergitol 15-S-3 and 0.25 parts of Tergitol 15-S-9 per 100 parts of distilled water. (These products are available in small quantities from TALAS (Division of Technical Library Service Inc) 213 West 35th Street, New York, N.Y. (212) 465-8722.) The recording must then be rinsed thoroughly with distilled water to eliminate any trace of detergent residue."
He then went a step farther and offered to give me some Tergitol 15-S-3 & 15-S-9. Thanks Frank!
So, it's time for me to help spread the word..:
I picked out a very dirty, but scratch free Areosmith "Get Your Wings".. While it may not be an "audiophile" album, it fit the profile for a Guinea Pig as it was absolutely unusable as it was..
I mixed in 10 ml of each Tergitol product into a gallon of Distilled water.. (total cost 83 cents) miture rate 400:1:1 and bought a few extra gallons of distilled water... I used an oral syringe purchased from Walgreens to measure the 10 ml accurately. It is reported to be VERY important to get the ratio correct. using more Tergitol is said to be a very bad thing as it can leave a residue in the wrong ratio.
I then put the mix in a spray bottle and sprayed the mix onto "Aerosmith GYW". spread it around with the brush from a Parastat and let it sit a minute or so before rinsing with the Distilled water... Guess what.. Shiny vinyl with no apparent residue film and very low surface noise.
This is the best cleaner mixture I have ever tried...
Now on to making a automatic Disc Washer with a Ice Cream Maker motor..
Thanks again Frank.
Thanks again Frank.
