jhoak
Well… Not my first speaker build but certainly one of my biggest.
I got laid off a couple of months ago so I have a lot of time on my hands but not a lot of $$ to spend.
I’ve been thinking about a pair of Cornscalas for quite a while now. Selling my La Scalas at a good price was all it took to push me over the edge. For those unaware of the term “Cornscala” it’s the bass section of a Klipsch Cornwall (15” direct radiator) with the midrange horn and tweeter of the La Scala. The design was first proposed by Bob Crites a few years ago. There have been a LOT of Cornscala builds since then. What you’re about to see is my version.
Let’s start with the rough cabinets.
I went through a couple of different midrange horn versions before I stumbled across a pair of M Audio M2380 horns (clones of the JBL 2380 2” horns) and a pair of Selenium D405 2” drivers. With the very gracious help of Mr. Crites I was able to design an appropriate crossover.
And get everything assembled in to something that actually resembled a pair of speakers.
From there they went (unfinished) to the living room for a couple of weeks of break-in and listening tests. Conclusion… VERY nice. Definitely worth veneering and keeping.
Which brings us to:
And finally:
For the curious the driver compliment is: Crites CW1526C woofers, M Audio M2380 horns with Selenium D405 2” drivers, and Eminence APT150 tweeters.
Associated equipment:
Preamp = McIntosh C32
Amp = Bob Latino VTA/ST-120 with Tung Sol KT120s, Electro Harmonix 12BH7Gs, Psvane 12AU7, Weber CW68
Tuner = Teac T-R670 (a Sansui TU-417 is on its way to me)
CD Player #1 = Cary 300/303
CD Player #2 = Sony SCD-CE595
DAC = Emotiva XDA-1
Turntable = Dual 1249 & Ortofon Blue
Subwoofer = DIY 12" sealed subwoofer w/GR Research SW-12B & Dayton 250w plate amp
Interconnects = Mostly DIY built with a good RG6 and compression RCA connectors
Speaker Wires = Tributaries 12Ga with Nakamichi locking banana connectors
Preliminary VERY unscientific testing using my ancient Onkyo M-506RS amp and a Rat-Shack SPL meter tells me that they put out somewhere in the 100dB to 102dB range at 1 watt. Pretty efficient. By that measure I should be able to drive them to 114dB or so with the 60 watts from the ST-120 should the need ever arise.
Of course the obvious question is “how does it sound?”. Let’s just say that I don’t have the words. The ones that immediately come to mind would be censored.
Which brings us to:
And finally:
DAC = Emotiva XDA-1
