SA-1000 Transistor list
larryderouin
I'm VERTICAL and Breathing...most of the time.
SA-1000 Transistor list need to VET
EDIT:30SEPT13 10:55pm FINAL LIST is in POST #10. Thank you MATTSD.
I made this up this afternoon (nothing else to do). This is all the transistors on it.
If Mark the fixer or Mattsd would be so kind as to Vet it, I'll add it to SoCal's thread. And i might be able to come up with a caps list. I pulled them from recent (less than 6 months old) threads using the transistor # and looking for a similar era unit (1971-73) AND the same type board. I used Mouser for the pricing.
PIONEER SA-1000
PRELIMINARY TRANSISTOR LIST.
Once Mark the Fixer or MATTSD vets it, I will remove preliminary.
Power Supply W16-035
q1 2sd234 512-KSC2073TU $0.67
q2 2sc373 512-KSC2383YBU $0.52
d5 fr2-02 512-1n4004 $0.14
dz wz-130 512-1N5243B $0.12
D1-D4 sr3am 512-1n5404 (4) $0.46ea
Protection Circuit W28-008
Q1-2 2sc983 -> 512-KSC2383YTA $0.52ea (2)
Q3-4 2sc945 -> 512-KSC1845FTA $0.20 (2)
Q5 2sa572 -> 512-KSA992FBU .07ea
Q6 2sc968 -> 512-KSC2383YTA $0.52
Q7 2sc495 ->512-KSC2690AYS $0.40...you may have to enlarge the holes for the leads to fit.
FILTER UNIT(W28-004)
Q1,Q2 = 2SC870-E =>>>> KSC1845FTA
Head Amp W21-007
Q1 thru Q6 2sc1000 -> 512-KSC1845 FTA(6) $0.20ea
Control Amp W15-050
Q3 thru Q6 2sc458lg -> 512-KSC1845FTA (x4) $0.20 ea
Main POWER AMP W23-008
Q1 thru Q4 2sc572 -> 512-KSC1845FTA (match them) (x4) $0.20ea
Q5,thru Q8........2SC627 -> 512-KSC3503ES(4) $0.47ea
Q9-Q10.............2SC984 -> 512-KSC2383YTA (2) $0.52ea
Q11-Q12...........2SC484 -> KSC2073TU(2) + heatsink (2) $.67ea plus heatsink
Q13-Q14...........2SA484 -> KSA940TU (2) $0.69ea.
Q15-16-17-18..2SC1080 -> 863-MJ21194G npn to-3 250v 16A 250W 4mhz 8-75hfe $4.07ea(x4)
TO-220 heatsink 532-6237B $0.52ea (2)
SHOTGUN Total for above as of 25Sept2013 $31.88. Plus shipping.
DO NOT USE THIS LIST IF IT SAY's PRELIMINARY at the top of this list
Larry
I would like to get this vetted before I finish the cap list. then link it to Marty,Socal's list's thread.
Partially. I talked to my uncle Friday. He still has his although it's in the attic in the box. He wants me to go thru his also. AND it'll help Drummergrl with hers, and anyone later on with one should they decide to use it.
Larry
Hi Larry,
What would I do without hifiengine:scratch2:
quasi-complementary PA!! = old school
These are my recommendations/changes as opposed to what you determined/listed.
Will see what the rest have to say, if they have actually done one of these, they may know more/better than I.
PS:
mje 15028,15030,15032[hfe =70 (Min) @ IC = 0.5A]
PA: (only one channel shown)
Q1,3=a992(matched for hfe or vbe)
q5=c1845
Q7,Q11=c3503 or c2690(A)(Y) (i'd try both in simulation and on the bench with a distortion analyzer, c3503 might be too fast = oscillations, need to check with a scope.
Q13=a1381 or a1220(a)(y)
Q11 = mje 15028,15030,15032[hfe =70 (Min) @ IC = 0.5A]
if you have not noticed, fairchild does not offer similar hfe ranking on the a1381/c3502 anymore = impossible to match
ecaps?
Rick
Rick; I did the E-caps finally y'day on a separate thread. When everything is finalized, and vetted I'll combine them and ask for a lock on the original threads.
Larry
PIONEER SA-1000
q1 2sd234 512-KSC2073TU $0.67 (Yes, will work fine. Can also use a MJE15032)
q2 2sc373 512-KSC2383YBU $0.52 (Yes, will work fine, but use the YTA, the YBU is obsolete)
d5 fr2-02 512-1n4004 $0.14 (No, use a 1n5404, the 1n4004 is only a 1 amp rectifier, the fr2-02 is 2 amps)
dz wz-130 512-1N5243B $0.12 (Yes, that will work fine)
D1-D4 sr3am 512-1n5404 (4) $0.46ea (Yes, that will work fine)
Q1-2 2sc983 -> 512-KSC2383YTA $0.52ea (2) (Yes, that will work fine)
Q3-4 2sc945 -> 512-KSC1845FTA $0.20 (2) (Yes, that will work fine)
Q5 2sa572 -> 512-KSA992FBU $0.07ea (Yes, that will work fine)
Q6 2sc968 -> 512-KSC2383YTA $0.52 (Yes, that will work fine)
Q7 2sc495 ->512-KSC2690AYS $0.40...you may have to enlarge the holes for the leads to fit. (Yes, that will work fine)
Q1,Q2 = 2SC870-E =>>>> KSC1845FTA (Yes, that will work fine)
Head Amp W21-007
Q1 thru Q6 2sc1000 -> 512-KSC1845FTA(6) $0.20ea (Yes, that will work fine)
Control Amp W15-050
Q3 thru Q6 2sc458lg -> 512-KSC1845FTA (x4) $0.20 ea (Yes, that will work fine)
Q1 thru Q4 2sc572 -> 512-KSC1845FTA (match them) (x4) $0.20ea (WHOAAA now! Those are 2SA572, not 2SC572. :D Replace with 512-KSA992FBU)
Q5,thru Q8........2SC627 -> 512-KSC3503ES(4) $0.47ea (Should work fine, use the 512-KSC3503DSTU, the ES is obsolete. Oscillation "might" be an issue, but I don't think it will be. @rcs16, the KSC2690 is even faster than the 3503, so it wouldn't work any better in terms of oscillation problems)
Q9-Q10.............2SC984 -> 512-KSC2383YTA (2) $0.52ea (Yes, that will work fine)
Q11-Q12...........2SC484 -> KSC2073TU(2) + heatsink (2) $.67ea plus heatsink (Yes, that will work fine, do not use On-Semi transistors for drivers, their VBE(on) voltage is too low, causing the bias to be non-existent or too high depending on the circuit design)
Q13-Q14...........2SA484 -> KSA940TU (2) $0.69ea. (Yes, that will work fine)
Q15-16-17-18..2SC1080 -> 863-MJ21194G npn to-3 250v 16A 250W 4mhz 8-75hfe $4.07ea(x4) (Yes, that will work fine)
Larry
Answers above in bold.
Larry
Larry, great news! An AKer local to me, baco99, is going to recap (and whatever else) my SA1000! He says he needs a schematic. Anyone have one?
When will markthefixer approve the list? I'm eager to get started. Thanks.
Final list.
SA-1000...... TRANSISTOR LIST. .
FINAL LIST...With BOM....OK to USE
FINAL LIST...WITH BOM....OK to USE
q1 2sd234 512-KSC2073TU $0.67 Can also use a MJE15032
q2 2sc373 512-KSC2383YTA $0.52
d5 fr2-02 512-1n5404
d7 wz-130 512-1N5243B $0.12
Q1,Q2 = 2SC870-E =>>>> 512-KSC1845FTA (2)
Head Amp W21-007
Control Amp W15-050
Q3 thru Q6 2sc458lg -> 512-KSC1845FTA (4) $0.20 ea
Q1 thru Q4 2sa572 -> 512-KSa992FBU(match them) (x4)
Q5,thru Q8........2SC627 -> 512-KSC3503DSTU(4) $0.47ea
MATTSD COMMENT:"Oscillation "might" be an issue, but I don't think it will be".
Q11-Q12...........2SC484 -> 512-KSC2073TU(2) + heatsink (2) $.67ea plus heatsink
MATTSD COMMENT:"Yes, that will work fine, do not use On-Semi transistors for drivers, their VBE(on) voltage is too low, causing the bias to be non-existent or too high depending on the circuit design"
Q13-Q14...........2SA484 -> 512-KSA940TU (2) $0.69ea.
512-KSC2073TU
512-KSC2383YTA
512-1n5404
512-1N5243B
512-1n5404 | 4
512-KSC2383YTA | 2
512-KSC1845FTA | 2
512-KSA992FBU
512-KSC2383YTA
512-KSC2690AYS
512-KSC1845FTA | 2
512-KSC1845FTA | 6
512-KSC1845FTA | 4
512-KSa992FBU | 4
512-KSC3503DSTU | 4
512-KSC2383YTA | 2
512-KSC2073TU | 2
512-KSA940TU | 2
863-MJ21194G | 4
532-6237B | 2
.......................END OF LIST.................................................................
Larry
Fixed. I've got Ulnar neuropathy in my left hand, and haven't gotten used to using only 1/2 of my hand when typing.
Larry
Hi Larry,
mattsd did a better job than I, sorry about stating c3503 is faster than c2690, well they are about the same ft 150MHz vs 155. I should learn to read before I write.
This makes sense.
Would state lists to be prelim. until one has actually used these parts, measured/tested to be certain.
rcs16. no problem. this is my 1st list I've put together. So I knew going in there were going to be some problems or mismatches.
If/when my Uncle ships his to me, I'll keep the Q11-12 in mind when testing, although I don't have much more than a DMM and a single channel 10mHz scope. So it's going to be limited at that. I should be able to pick up the oscillations(if any) on the scope using a signal from the laptop audio generator, correct?
Larry
Oscillation should not be a problem, c15, c16 ( 27pf), c17, c18 (330pf) should see to that.
Physical details: Q9, Q10 2sc984 are part of a circuit called a "Vbe multiplier" and they have the same essential function at a thermal bias diode.
It remains to be seen how the thermal coupling to the heat sink is implemented, (and which components are left behind on the board ) so a to-92L transistor may not be the best choice, and a to-126(512-ksc3505xxx) or a to-92(512-KSD1616xxx) or may be a better choice - purely due to mechanical mounting considerations.
I have used BOTH in similar situations, and in the case of the d1616, if you have c1845's they too will sub well (but while I haven't actually used one in a circuit like that, there should be NO electronic problems)
at that time, pictures are encouraged, and swearing may be experienced.
Consider this my okay-dokey on the list.
