Sa-1000 consolidated parts lists
larryderouin
I'm VERTICAL and Breathing...most of the time.
Here are the FINAL, READY TO USE TRANSISTOR List and the CAPACITOR, DIODE, miscellaneous Parts list for the SA-1000. This was consolidated from 2 separate threads which will make it easier for future users. The part #'s were good as of the date of this post. Future users will need to determine if the parts are still available and if not, suitable replacements for each part. PART's are sourced from MOUSER and this is reflected in the part #'s.
NOT ALL PARTS WILL BE USED. THEY ARE CARRIED HERE FOR COMPLETENESS!
SA-1000 TRANSISTOR LIST
Power Supply W16-035
q1 2sd234 512-KSC2073TU $0.67 Can also use a MJE15032
q2 2sc373 512-KSC2383YTA $0.52
d5 fr2-02 512-1n5404
d7 wz-130 512-1N5243B $0.12
D1-D4 sr3am 512-1n5404 (4) $0.46ea
Protection Circuit W28-008
Q1-2 2sc983 -> 512-KSC2383YTA $0.52ea (2)
Q3-4 2sc945 -> 512-KSC1845FTA $0.20 (2)
Q5 2sa572 -> 512-KSA992FBU $0.07ea
Q6 2sc968 -> 512-KSC2383YTA $0.52
Q7 2sc495 ->512-KSC2690AYS $0.40...you may have to enlarge the holes for the leads to fit.
FILTER UNIT(W28-004)
Q1,Q2 = 2SC870-E =>>>> 512-KSC1845FTA (2)
Head Amp W21-007
Q1 thru Q6 2sc1000 -> 512-KSC1845FTA(6) $0.20ea
Control Amp W15-050
Q3 thru Q6 2sc458lg -> 512-KSC1845FTA (4) $0.20 ea
Main POWER AMP W23-008
Q1 thru Q4 2sa572 -> 512-KSa992FBU(match them) (x4)
Q5,thru Q8........2SC627 -> 512-KSC3503DSTU(4) $0.47ea
MATTSD COMMENT:"Oscillation "might" be an issue, but I don't think it will be".
Q9-Q10.............2SC984 -> 512-KSC2383YTA (2) $0.52ea
Q11-Q12...........2SC484 -> 512-KSC2073TU(2) + heatsink (2) $.67ea plus heatsink.
MATTSD COMMENT:"Yes, that will work fine, do not use On-Semi transistors for drivers, their VBE(on) voltage is too low, causing the bias to be non-existent or too high depending on the circuit design"
Q13-Q14...........2SA484 -> 512-KSA940TU (2) $0.69ea.
Q15-16-17-18..2SC1080 -> 863-MJ21194G npn to-3 250v 16A 250W 4mhz 8-75hfe $4.07ea(x4)
TO-220 heatsink 532-6237B $0.52ea (2)
512-KSC2073TU
512-KSC2383YTA
512-1n5404
512-1N5243B
512-1n5404 | 4
512-KSC2383YTA | 2
512-KSC1845FTA | 2
512-KSA992FBU
512-KSC2383YTA
512-KSC2690AYS
512-KSC1845FTA | 2
512-KSC1845FTA | 6
512-KSC1845FTA | 4
512-KSa992FBU | 4
512-KSC3503DSTU | 4
512-KSC2383YTA | 2
512-KSC2073TU | 2
512-KSA940TU | 2
863-MJ21194G | 4
532-6237B | 2
.......................END OF LIST.............................................. ...................
SA-1000 CAPACITOR AND DIODE LIST.
Again not all parts will be used, but are included for completeness. The MAIN FILTER CAPS ARE NOT listed.
Pioneer SA-1000 recap list with diodes, diodes don't have to be replaced unless they are proven by testing to be bad.
Head Amp Board (W21-007)
W21-007: C1: 1uF 25v CSSA: 667-ECQ-V1H105JL3 1uF 50v
W21-007: C2: 1uF 25v CSSA: 667-ECQ-V1H105JL3 1uF 50v
W21-007: C3: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W21-007: C4: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W21-007: C5: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W21-007: C6: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W21-007: C15: 100uF 35v CEA: 647-UPW1H101MPD 100uF 50v
Control Amp Board (W15-050)
W15-050: C1: .1uF 25v CQMA (Mylar): 667-ECQ-V1H104JL3 .1uF 50v
W15-050: C2: .1uF 25v CQMA (Mylar): 667-ECQ-V1H104JL3 .1uF 50v
W15-050: C3: 30uF 6.3v CEA: 647-UPW1C330MDD 33uF 16v
W15-050: C4: 30uF 6.3v CEA: 647-UPW1C330MDD 33uF 16v
W15-050: C7: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W15-050: C8: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W15-050: C11: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C12: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C13: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C14: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C15: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
Filter Board (W28-004)
W28-004: C9: 1uF 25v CEA: 647-UPW1H010MDD 1uF 50v
W28-004: C10: 1uF 25v CEA: 647-UPW1H010MDD 1uF 50v
W28-004: C19: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W28-004: C20: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W28-004: C25: 220uF 25v CEA: 647-UPW1E221MPD 220uF 25v
Main Amp Board (W23-008)
W23-008: C1: 2.2uF 25v CSSA: 647-UKL1H2R2MDDANA 2.2uF 50v
W23-008: C2: 2.2uF 25v CSSA: 647-UKL1H2R2MDDANA 2.2uF 50v
W23-008: C5: 22uF 6.3v CEA: 647-UPW1A220MDD 22uF 10v
W23-008: C6: 22uF 6.3v CEA: 647-UPW1A220MDD 22uF 10v
W23-008: C11: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W23-008: C12: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W23-008: C13: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W23-008: C14: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
VR1: 4.7K ohm multi offset: 652-3296Y-1-502LF 5K ohm 25 turn
VR2: 4.7K ohm multi offset: 652-3296Y-1-502LF 5K ohm 25 turn
VR3: 1.5K ohm single bias: 652-3386F-1-202LF 2K ohm single turn
VR4: 1.5K ohm single bias: 652-3386F-1-202LF 2K ohm single turn
D1: WZ-130: 512-1N5243B
D2: WZ-130: 512-1N5243B
D5: 1S1212: 512-1N4148
Protection Board (W28-008)
W28-008: C3: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W28-008: C4: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W28-008: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
D1: SIB01-005: 512-1N4005
D2: SIB01-005: 512-1N4005
D3: SIB01-005: 512-1N4005
D4 SIB01-005: 512-1N4005
D5 SIB01-005: 512-1N4005
D6 SIB01-005: 512-1N4005
D7 SIB01-005: 512-1N4005
VR1: 100 ohm single turn: 652-3386F-1-101LF 100 ohm single turn
Power Supply Board (W16-035)
W16-035: C2: 1000uF 10v CEA: 647-UPW1E102MHD 1000uF 25v
W16-035: C3: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C4: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C5: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C6: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C7: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
D1: SR3AM-8: 512-1N5404
D2: SR3AM-8: 512-1N5404
D3: SR3AM-8: 512-1N5404
D4: SR3AM-8: 512-1N5404
D5: FR2-02: 512-1N4004
D6:1s1850: 1n4004 (x2) (original is dual diode cathode to center)
D7: WZ-130: 512-1N5243B[/b]
D8: Germanium diode leave it be. No readily available replacement.
D9: Germanium diode, leave it be. No readily available replacement.
Filter caps (need measurements of the main filter caps to determine replacements):
C33: 4700uF 50V
C34: 4700uF 50V
C35: 4700uF 50V
C36: 4700uF 50V
C37: 1000uF 63V
C42: 47uF 50V CEA: 647-UPW1J470MPD 47uF 63v
BOM List:
667-ECQ-V1H105JL3 | 2
647-UKL1H2R2MDDANA | 2
647-UPW1H4R7MDD | 4
647-UPW1V100MDD | 8
647-UPW1J101MPD | 6
647-UPW1H101MPD | 1
647-UPW1E101MED | 1
647-UPW1C330MDD | 2
667-ECQ-V1H104JL3 | 2
647-UPW1H221MPD | 2
647-UPW1E221MPD | 5
647-UPW1H010MDD | 2
647-UPW1A220MDD | 2
647-UPW1J470MPD | 1
647-UPW1E102MHD | 1
652-3296Y-1-502LF | 2
652-3386F-1-202LF | 2
652-3386F-1-101LF | 1
512-1N5243B | 3
512-1N4005 | 7
512-1N4148 | 1
512-1N5404 | 4
512-1n4004 | 3
The individual threads are
TRANSISTORS: See POST #10 http://www.audiokarma.org/forums/showthread.php?t=546251
CAP LIST: SEE POST #10 http://www.audiokarma.org/forums/showthread.php?t=546934
I know this is more than 12 years old.
D5 of Power supply is shown as 1N5404 on the transistor list
but 1N4004 on the cap list?
Will both work? Thanks.
if anyone is still looking at this post.
1n4004 is only 1A rated. It could work, but better to use 1n5404 which is 3A rated (the original fr2-02 is rated for 2A)
