I just acquired a non-working Nohr SE-9. I have very little history on it other than it would seem a previous owner must have added a fuse because several reviews say it has no fuse. At this point I'm unsure if it was original or added but the note that came with the amp said the fuse blows after 5 minutes or so. The note also says it was a 2 amp fuse. Here again my research shows some discrepancies. The reviews say it consumes 80 watts but the sticker on it says 30 watts. I've read in one forum a 6 amp fuse was used. So what I really want to start out with is what size fuse should be used, because maybe the unit is fine but it was under fused by a previous owner. I could also just replace all the tubes but I'd rather not if it's not required.
So if someone has one and can help me with a starting point I'd really appreciate it. BTW, I tried emailing Norh but the email bounced back immediately, not sure why.
Thank you-
Thank you-
