Akai AM-2600 worth fixing?
Keessie
I have some little problems with my AM-2600 it plays but when i turn it on there is a irritating static sound for over a minute and also when i tunt up the volume
is it better to take it out for repair or look for a another one?
Greets
Keessie
Very worthy of service/repair, sounds like a basic cleaning/service of the switches and pots will go a long way toward curing the symptoms you describe. Problems could run a bit deeper, but a thorough cleaning is where i'd start.
Thanks for the quick reply Bowtie427ss
i will send the amp as soon as possile out for cleaning/repair
Greets
Keessie
It really is an easy thing to do yourself. No real need to send it out. There are several threads here for how to "Deoxit" your controls. I think there is a long detailed one as a sticky in the DIY Section. And that unit is definitely worth the effort!
Greets
Keessie
It is relatively easy and cheap to fix the volume control problem, as one simply cleans it with Deoxit. But the static for over a minute when you turn it on might be something more serious, requiring a repair. I would recommend using Deoxit on all the controls, and then see how it performs. But from what you say, I think it might also have something else wrong with it.
I will try the Deoxit.
But i also think that the static when i turn him on is something more serious like a loose contact somewhere in the amp and my electronics is't that good and i don't want to ruin my amp
Thanks guys for the quick and helpfull reply's
Greets
Keessie
Greets
Keessie
I would think it is something else other than a loose contact for the noise when you first turn it on. If it always is there when you first turn it on, and always goes away after a minute or so, it likely works after it is warmed up, which doesn't sound like it would be a loose contact.
As for whether or not it is worth fixing, it is going to depend upon how much you like it, how much it will cost to fix it (a repair shop should be able to make some sort of guess, but will not likely be a firm price without looking at it), and what else you can get. I would expect it to be a relatively inexpensive repair, so if you really like the unit, it is probably worth fixing.
Hi Pyrrho,
I like this amp very much looks great and the sound is full and warm.
It is not in a bad shape just need a bit work and got it for free so i think i can spend some to get it at his full potential.
Greets,
Keessie
The static that happens while you move the control is the wiper moving over the dirt, dust, and grime that's inside the potentiometer.
Also, as was the case with my AM-2600, the speaker protection relay contacts may be pitted a bit and might need a light burnishing to get them good again.
Also, the matching tuner is somewhat of a treat if you run across it.
Tomorrow i hope the Deoxit will arrive so i can clean him up hopefully the most problems are solved than
Your Am-2600 looks very nice :D
The AT-2600 is often at the dutch auctionsites and most of them see them as junk
Just like the Akai Am series
I liked mine before i knew what it's worth
I have now bought a AM-2450 too but has some problems have a made a another thread for it
Greets Keessie
Deoxit has solved much of the problems but sometimes the right channel is distorted.
Most of the time when i am gaming with my racing wheel.
Could it be a cracked solder point? i have looked at the main pcb but did'nt see anything like it.
How can you see that it is a bad solder point?
