Got the power supply done and was listening to FM a for a bit. Everything was working great for about 10 minutes, then there was a pop and no more FM. The TO-220 transistor (2SD234) that sends power to the MPX board celebrated the 4th a little early. I checked the voltages right after powering it back up and they looked ok so I'm reasonably sure I didn't make a mistake in re-capping the power supply. I unhooked the wires from the 2SD234 to be sure and it's open from base to emitter, shorted from base to collector. The DBT is still dim so hopefully no major damage. I don't have any subs on hand so I'll have to order some but before I do that, I'll check the MPX board to make sure it looks ok. There is a 2SC548 on the MPX board that I didn't see when I was replacing them on the amp board.
