I've been just listening to the receiver on it so far and that sounds pretty good but decided to hook a laptop up to it and stream some old favorites through it. I have to say it sounds pretty amazing. The detail is really great. Still a few little issues to work out and I was getting a little down on this thing but listening to it for a while gives me some motivation to stick with it. The things I've read about these Kenwoods seem to be true. Really good tuners and great sound.
Here's a pic of the inside to show where it's at overall. I replaced all the brown mylar caps because their coatings were chalky and coming off in places. They tested ok but I've read before that when the coatings are compromised they can fail so I figured it wasn't a bad idea to get them out. The replacements are WIMA polypropylenes which should sound better anyway. The 1uF PP's don't fit in perfectly. They're a little large for the space and sit on top of some other components a bit but they worked. Everything bigger than 1uF are still electrolytics since I couldn't find film caps that were small enough. I tried to replace all the signal path caps with bi-polars as much as I could. Some that were higher voltage are audio-grade polarized though. I left the two green mylar caps in because they looked fine and I didn't have an exact value replacement on hand. I went with 6800uF for the output caps.
