It's got dual voice coils, so you hook up to both to get the best response from it.
Watkins did this with the two windings being different ...?crossover points/ impedences so it smoothed out resistence and also extended bass response. The Volkswoofer will DEFINITELY function better with both hooked up. use two channels if you have them, if you only have one channel, measure impedence first to make sure you won't present a stupid low impedence load to the amplifier, then hook them up parallel.
yesput the two red together and the two black and then measure that?
Operation successful. And the beauty of it is that it's 100% reversible. The two pairs of speakers terminals were even connected with little plugs so I didn't have to cut or even desolder anything.
No hum, no buzzing, no popping. Just nice tight bass.
Pretty darn sweet!
This little amp even has gain configuration so it now all runs like a normal sub (I don't have to run it full blast of add a gain thingy to increase gain)
View attachment 2604911 View attachment 2604912 View attachment 2604913
i actually thought "butyl" since i have a big roll of 3m window weld. i'd just center the wire and pack butyl around it.Chances are you'll never have an issue, but my mind is screaming at me GROMMETS.
Or maybe 2 or 3 wraps of tape where they enter the cabinet.
Yup this isn't yet final. I'll probably open it back up and try the serial idea and then put in some grommets.Chances are you'll never have an issue, but my mind is screaming at me GROMMETS.
It's this one. I'm really impressed with it!Nice, what brand and model is your new amp?
THANK YOU!!!Bummer not to have the original amp working properly. On the point of grommets, I know that when the little cap was removed from the frequency adjust hole on my V1B that sucker would whistle like crazy on low bass notes!
