Lo-Fidelity
:thmbsp: Just going to clean it up. Too much family history to replace the old body with a jeweled case (but they are pretty).
Warning: WD-40 is a solvent and will probably remove any/all remaining lettering on the chassis. Also, once removed or evaporated, it leaves no lasting protection against oxidation.
I'll freely admit I've never risked McIntosh chrome lettering by exposure to WD-40, so it's possible it won't react with the lettering.
However, here are the facts:
The WD in WD-40 stands for "water displacing." While the volatile carrier is in place, it does a decent job at keeping water and oxygen away from the base metal. Unfortunately, the carrier is volatile and nearly the entire formula evaporates. Regardless of how it gets applied, it ends up in the air - not on your part. The remaining thin layer does not protect against corrosion.
An un-corroded chassis in mint condition may not need protection if the metal isn't exposed. An already corroded chassis needs all the help it can get; once the oxidized regions are again in contact with air, they'll continue to react.
WD-40 is a good (great, even) agent against rust, and could be used as an initial pass on a corroded unit. But that had better be followed up with some actual corrosion protection.
This is all very well known in machinist circles.
Finally, regarding Wenol, that product leaves no microscratches when correctly applied with microfiber cloths/towels. You must move very often to clean areas of cloth, though, or the dust and debris you just wiped away scratches the chrome as it is dragged along. That sounds like your experience.
I do warranty work for McIntosh at a shop I work for and at my home shop I refurbish the older ones. Unless the transformers are electronically unsound, the amps can be made to work again. You would not believe some of the cosmetically challenged Macs i have refurbished. Once done, they may not be pretty but they sound excellent. I presently have a couple McIntosh 60's from the late 50's that look horrible, pitted chassis, scrapes and dents and such, but they sound amazing. I drive them with a MX110. To me, any Mac is worth refurbishing. I have yet to find a McIntosh amp I don't like. Yes, some sound better then others, but in the world of amps, McIntosh never made any junk, And I have worked on everything from MC30's to MA8000's.
Take that 240 and get it working again. I just finished recapping a 240. Those things sound amazing. I actually prefer that one to the 275.
