indosmokejon
A local audio acquaintance let me borrow his ampex el34’s and after a very short listen I was hooked. Not sure if my vandy 2ce sig II’s have ever sounded as good. They liked the power, as I mostly run smaller/weaker tube amps. I have owned many other large tube amps that put out 40-60 watts, from dynaco mkiii’s, st70, quicksilver kt88, etc, but I never heard any of them stand out, so they were sold. The ampex just grabbed my attention. The acquaintance wanted a hefty $1100 for his pair and so I passed, and found a rough pair for less. I bought them sight unseen, had a friend grab them, then waited 8 months due to Covid to finally get them this week. They are rough, and someone tried to update them, did it wrong, and they clearly haven’t worked since. One of the filter caps positive lead goes to ground! I’m not an amp engineer, but I am good at polishing a turd. These will be polished. I need help on the engineering side. These sounded amazing to me but I’m sure they could sound better, and I have questions. These mono’s are the true el34 variant, with the opt that are larger than the pt, solid state rectification, 40W per, and 16ohm secondaries.
