aidynphoenix
Super Member
I took apart my Yamaha M-4, im preparing for a recap, im still waiting on the caps to arrive. so in the meantime i wanted to get something started, I decided to clean all the boards, and connectors inside. first i used a basic electronic contact cleaner on the green backside of each board, this was cheap CRC contact cleaner, i tilted the board at a angle and allowed this to carry dirt off the board and collect into a paper towel, and used a toothbrush to remove the dust, dirt or whatever else was left on there.
than for the front side with the components i started out with a dry 1inch paintbrush, to remove the dirt and dust.
after i got rid of the dust and dirt, i used small amounts of deoxit d100 and coated all the component leads and solder connections with it, i used another 1inch paintbrush to spread it around and on everything.
i did this on both sides of the boards.
i used deoxit on the boards and solder connections because they were not shiny and clean looking like a fresh component, they were more dull and grey than a shiny chrome color.
i assume this is built up dirt corosion or oxidation.
I learned here in the past that when copper speaker wires that are exposed to air and oxidise they will loose signal quality.
i dont see why this could be much different than tinned copper connections.
My amplifer sounds much more open and crisp after the cleaning than it did before.
im hearing things in my favorite songs and they are suprising me.
im sure i will hear a bigger improvement after the recap, but i thought i would share the differences im hearing after simply cleaning the components, leads, boards and connections.
