frankxbe
Super Member
(Reuters) - General Motors Co is recalling 473,841 Chevrolet, Pontiac and Saturn sedans globally to fix a condition that could lead the cars to roll when the drivers think they are in park, the No. 1 U.S. automaker said on Friday.
GM said it was aware of four crashes that resulted from the problem, but no injuries. read more here
My post @yahooligan
Ford had that same problem on untold millions of cars for decades they would drop out of park into reverse with the motor running or from neutral into drive as well .Not safe to scrape ice off of your windhirld while the motor and heater were running! They could start in gear also. Poeple were getting run over by their own cars ! What did NHTSA do ? They made Ford give out stickers telling people to keep their foot on the brake when the car was parked and running and to use their parking brake. Problem was the parking brakes mostly did not that work that well either. Found On The Road Dead or in your driveway
could certainly apply here.
Good reason for starter/brake pedal interlocks and clutch safety switches that we have now.
To be fair Ford and GM are not the only car makers with safety issues then or now.
There are/were plenty to go around . Other cars has doors that would fly open when going around a corner ! ( Believe me you wanna be belted in when that happens !) , or seat backs that would break while you were driving ,suddenly you are reaching for the wheel ! GM had millions of bad motor mounts causing throttles to stick they never fixed the motor mounts but they did retro fit restraining cables. All the car companies had cars that would frequently stall on the highway without warning early electronic ignition system reliability problems .Some were recalled most not. Just a couple of many reasons in addition to crash safety is why NHTSA came into being.
I think Honda,Toyota and others have some stuff going on now also.
Ford according to this has a steering issue with the crown Vic's
Good idea to check your vehicle once in awhile some issues don't surface for years .
Here is good place to check your vehicle for recalls/equipment and safety issues.
http://www.safercar.gov/
My post @yahooligan
