bordeno
Super Member
I'm sure this has been discussed before, but I'd like some info/ opinions here.
First off, what exactly IS "Damping Factor?" I know it has to do with woofer control, thus it affects the perception of the bass in your system, but how? Also a high damping factor is supposedly better, but how important is that spec when you're comparing power amps? What do manufacturers do to a power amp to give it a high damping factor?
Most Japanese receivers/ amps from the '70s did not have high damping factor, with numbers like 60 or so.
Many separate amps boast of high DFs; apparently some don't attach alot of importance to it, for example the Yamaha MX 600 I have only has a 70 damping factor but its still a nice amp.
Start waxing eloquent, comrades...
