gyrene
No Marconi:Gomer MacGyver
My KT7500 is an old dog but still plugging away.
I bought it used...of course and the mods make it sound great.I'm very happy with what I did.
Some of the mods to it can be found here: http://www.fmtunerinfo.com/DIY.html#KT-7500
The one titled: John Camille's snubber circuit has got me stymied.
Here is what it says: (2) I added John Camille's "snubber" circuit after the fuse and before the transformer. The snubber circuit consists of two 10-Ohm, 5-watt resistors in series with the AC wires. One resistor is in series with the hot and one with the neutral. On each side of the resistors and strapped between them are two .01 µF 400-volt or higher disc capacitors. Don't use some generic film cap because of its unknown time constant. Next raise the power transformer 1/2 inch off the chassis on INSULATED standoffs so the transformer is not grounded to the chassis. I also replaced the power cord with a heavier gauge polarized cord. I oriented the cord for the least AC leakage, measured from the chassis to ground
Is it going to look like this:
AC hot >10ohm 5w > .01uF>pcb?
AC neutral >10 ohm 5w> .01uF>pcb
Thats it? If it works...how does it work? Whats it doing? Shunting stray signals to ground?
Has anyone any experience with the KT7500 and mods done to it?
