New Large Advent
NLA bullnose, factory stock as best I have determined, recently refoamed, with foam cabinet damping, on centerline axis at tweeter height, grille removed:
Nearfield low-frequency response and effect of grille:
Same data for unit #2, in which the factory foam has been removed and replaced with a lining of R-13 fiberglass. Lt. grey is unit #1 at "Normal" in all unit #2 measurements for comparison:
10° Polar Response:
Sinusoidal measurements comparing units #1 and #2 with grille, attenuation at Normal setting, and nearfield low-frequency response with the grilles removed:
Comments:
1) The grille levels a peaky high-frequency response somewhat, highest at 13.4 kHz. On-axis, the HF response rolls off steeply above 16 kHz.
2) Even with the grilles on, the "Decreased" attenuation setting provides the flattest on-axis response.
3) Toe-in is required for retention of limited HF response above 13.4 kHz.
4) As earlier found with OLA, the bass peaks at ~70 - 80 Hz
5) To the extent that the bass response is perceived as "boomy" with boundary reinforcement, this may be improved somewhat with fiberglass damping in lieu of the stock foam. Nearfield measurements reflect bass response in 2-Pi alignment, i.e., one boundary, wall or floor.
6) Bass response extends to ~35 Hz (-6 dB).
10° Polar Response:
Comments:
